[updated:LAST EDITED ON 13-Aug-02 AT 08:29 PM (EST)]I think aluminized sheeting of some sort would reflect the heat and last, of more importance than material as such, is to keep an air gap between the sheild and the tank, my guess would be at least an inch if the exhaust is close.
Sorry, should have added, for the starter the wrap (on the starter-not the header or pipe) has worked well on the few I've seen that needed it.
http://www.thermotec.com/tt/Images/barrier.jpg from the company's page: "The Aluminized Heat Barrier is made up of woven silica with a flexible aluminized finish. The highly-reflective surface of the material is capable of withstanding radiant temperatures in excess of 2000°F. This product can be installed using standard rivets with a backup washer or weather strip adhesive. The use of clamps or straps such as Thermo-Tec’s Snap Strap can be used to hold the blanket in place for manifolds or exhaust systems."
note to forum moderators: this is not an ad (by me), just meant to provide info.
