trans help
Old Jan 15, 2009 | 11:41 AM
aedfrsw's Avatar
aedfrsw
trans help
does any one know if a c6 from a 400 will bolt up to a 390.
thanks
mike
Old Jan 15, 2009 | 02:20 PM
zak8tac's Avatar
zak8tac
Just wanted to try to help you... From research on other threads it seems to me that no a c6 from a 400 won't bolt up to a 390. You have to find a c6 that is from anothe FE motor. Then apparently there is a whole other can of worms dealing with the output shaft and such. Good luck man.
Old Jan 15, 2009 | 03:04 PM
zak8tac's Avatar
zak8tac
There is a similar thread that maybe will better answer your question. Its titled "4 speed transmission swap question" today it was on the 3rd page back.
Old Jan 15, 2009 | 04:04 PM
aedfrsw's Avatar
aedfrsw
thank you for the help zak8tac
Old Jan 15, 2009 | 05:41 PM
tatonka04's Avatar
tatonka04
I just actually did the output shaft swap last month. The 75 in my signature had a c6 with some busted edges where the bolts go in to bolt it to the engine. Well, I found another FE c6 that was 2 wheel drive and gutted it, and put it back together with my output shaft. Worked out good. Numberdummy squared me away on that one.
