Bigger cat more flow?
Old Jan 15, 2009 | 09:55 AM
FordF350Baby's Avatar
FordF350Baby
I need to put cats back on my true dual.the smell is awful! Would putting a 3 inch cat on a 2 1/2 inch system promote more flow? Or should i just stick with the 2 1/2 inch?
Old Jan 15, 2009 | 10:40 AM
Conanski's Avatar
Conanski
3" cat gains nothing with 2.5" pipe on either side of it.
Old Jan 15, 2009 | 11:03 AM
FordF350Baby
well what about loudness?
Old Jan 15, 2009 | 11:52 AM
Conanski's Avatar
Conanski
Any cat will make the exhaust a bit quieter than no cat, but from personal experience it'll still be pretty loud.. much more than it is with the stock cats.
Old Jan 16, 2009 | 09:44 AM
Bear River's Avatar
Bear River
Former ******
Between the 2.5" and 3" I don't think you'll see a whole lot of difference in loudness. Yes the 3" will be a tad louder, but I think it would be hard to tell.
The cross section of the catalyst itself would be more of concern to me. There are only two ways to get more flow out of a cat. The first is to increase the cross section. W use this method a lot on trucks since the large casing also helps reduce raspiness and causes a deeper tone shift. The second is to use a lower cell density catalyst. This method works well, but the cost of the catalyst is much higher, and this option should only be used if smog legal racing is your thing.
Old Jan 16, 2009 | 10:12 AM
FordF350Baby
Okay, I just went with the 2 1/2inch then, keep it clean and simple, and dont have to bother getting adapters welded in.
Skandocious
Apr 29, 2007 06:36 PM
1986broncojoe
1978 - 1996 Big Bronco
May 11, 2004 09:33 AM
dnb5555
Exhaust Systems
Mar 8, 2004 05:50 PM
mrak
Exhaust Systems
Mar 10, 2003 07:27 PM
fordextreme
Exhaust Systems
May 23, 2002 08:37 AM
