Please Help!!!
Old Jan 14, 2009 | 01:23 PM
sofakingkrazy32's Avatar
sofakingkrazy32
Please Help!!!
Can someone please tell me what all hooks to the starter relay and what side. Thanks in advance
Old Jan 14, 2009 | 01:26 PM
sofakingkrazy32
I am sorry, its a 63 f100...
Old Jan 15, 2009 | 04:22 PM
Orange '63's Avatar
Orange '63
This might help - / 1964_08.gif. I would go out and look at my truck but it's just too cold. I know if you're facing the truck from the front the positive battery cable hooks to the right (drivers side) and the starter wire hooks to the left (passenger side). At least that's how mine is set up.
Old Jan 15, 2009 | 04:33 PM
SJ Bikesaws's Avatar
SJ Bikesaws
One terminal is marked S (the wire from the ignition switch goes to this one to activate the starter)
One is marked I or B (all others go on that one)
If they aren't marked, put the truck in neutral and run a jumper wire from the + bat to each terminal. The one that makes the starter turn is the S terminal.
If you lost the starter wire in the bunch, its much easier to find with a volt meter, its usually rubber capped but when the trucks are this old, who knows.
Old Jan 16, 2009 | 08:19 AM
sofakingkrazy32
Thanks
Thanks all, I hooked all the wires back up...everything was unhooked. The lights wipers ..etc work The truck just kind of makes a thump when tried to start.Any ideas.
Old Jan 16, 2009 | 08:59 AM
Flyn66dtmn's Avatar
Flyn66dtmn
has the engine been started ? use a breaker bar on the crankshaft and see if the engine will turn over by hand. if it doesn't you have more serious problems. the thumping youre refering to sounds like the starter is engaging but not turning the engine. could be a coupla other things also. Dutch
Old Jan 16, 2009 | 10:12 AM
sofakingkrazy32
The engine was running fine when it was put in, i just dont know if i have everything hooked up right, i think the starter is right but i am not sure if the ignition coil is hooked up right... could this cause it to do that? THX
Old Jan 16, 2009 | 10:38 AM
cobraguy's Avatar
cobraguy
We can better help if we had some more to go on. What engine and tranny are we working with. Does it turn now by hand. You may have something bound up. I've seen many like this from the torque converter not fully seated.
Old Jan 16, 2009 | 12:35 PM
sofakingkrazy32
The engine is a 73-79, 250 inline six, with a three speed trans, not sure which one yet.
slimfitz
1997 - 2003 F150
Aug 4, 2014 08:05 PM
vaughandw
Oct 9, 2013 09:13 AM
Daddywags
16
Jul 5, 2005 11:37 PM
