International V.S. Ford Built Diesels
#46
What compromises does Navistar have on the 6.4? The Duramax only meets 07 emissions specs as well. The Cummins and Duramax also both have an EGR. Mercedes diesels, even the Puegot diesels use an EGR are as well.
I don't see how Common rail injection, or fast spooling sequential twin VGT turbos are bandaids?
ALL diesel engines in both Europe and the US need a DPF and NOx absorber. They use the exact same emissions technology as we do here, infact ours is slightly better. The current US diesel emissions are MORE strict then the Euro IV specs. I also expect our 2010 emissions to be stricter then the Euro V/VI as wel.
And the cummins meeting 2010 emissions comes at a price. MASSVIVE emissions system failures are happening with the 6.7. The first year and a half it iwas out, on the cummins forum it was just pages and pages of DPF and Turbo failure because of excessive soot and sustained high temperatures.
You can sit there and argue who has what features until your blue in the face, it doesn't change the fact that Euro diesels are realistically 5 years ahead of Navistar and Navistar is FAR from cutting edge.
Look at what Ford/Peugeot, Audi and BMW have done with their diesels, all of these companies have produced diesels that blow ANYTHING we've seen from Navistar or even Cummins out of the water. Hands down.
#47
I'll put it to you like this, in 2005 the Euro Ford diesels had EVERY feature the 6.4 finally got in 2008, including gallery oil cooled pistons, piezoelectric injectors, DPF, pilot injection, common rail, and twin sequential VGTs. The difference is the execution was MUCH more elegant in the in Euro diesels, right down to the combustion chamber.
Your trying to compare apples to oranges. Euro Ford diesels are pass. car engines, not heavy duty diesels. There is a difference. Although they share technologies, heavy duty diesels require different fuel/timing maps and they must conform to a different set of emissions rules than pass. cars. North America was the first market to use EGR and dpf in heavy duty diesels.
#48
Cummins has had Piezo injectors and HPCR since 03, and the Duramax since 01.
Tell me though, how are the European solutions more elegant? How is the Dmax, Cummins, and Powerstroke 5 years behind european diesels, when they are all using the exact same technology? I mean some of them are LITERALLY using the exact same technology. The Bosch CP3 injection system is used on the Cummins and Duramax, and it and its variants are also used on many European diesels.
#49
#50
International introduced pilot injection on the 7.3 with the split-shot injectors. Every international engine ever used in a ford pickup has had oil cooled pistons - including the 6.9. When international brought out the HEUI system in 1995, it was one of the most advanced injection systems around. Almost everyone else, include most European diesels were still using injection pumps! They pretty much solidified the future of common rail injection. (The HEUI IS common rail). The 6.0 had a VG turbo back in 03. Just not two of em. DPFs weren't even required here until 2007, and regen nesicates multiple injections per cycle, while the current HEUI system could only provide 2. So they had to go common rail.
#53
ok i know i read the discussion on how ford doesn't own anything with cummins, so then can someone tell me why my parents can get a discount on all ford and all dodges because my dad works at cummins, and all the cars cummins has for out of town trips are fords, so if someone could explain that to me id be happy to hear it
#54
#56
Ford employees also qualify for supplier discounts for Dodge, GM, Dell, YMCA, Verizon, Sprint, etc, etc. Lots of companies offer discounts to big businesses because of the expected volume of business they will receive.
Did you know that Pizza hut employees qualify for X plan? YES that is true! Ford doesnt own these companies and Ford doesnt make laptops, cell phones or pepperoni. Its just a matter of companies doing business with one another.
In the case of Cummins, Ford does buy some engines for the big trucks so that makes Cummins a supplier. In good faith, nearly all suppliers offer employee discounts as a means of supporting the company that is puting food on their tables by purchasing parts, engines, whatever.
#57
#58
There are no Fords bigger than the 750, and yes the 650 comes with a 6.7L Cummins. In fact, as of 2009 the 6.7L Cummins is the only engine offered in these trucks. The 650 and 750 are built in Mexico by International for Ford. They are basically International 4400 chassis with a Cummins engine and a Super Duty cab. A mongrel if there ever was one. As for Ford's new diesel, I am optomistic. I don't think International ever really had a good truck diesel. Every one had issues, some more than others. The old 6.9L was about the best, the 7.3L had block cavitation issues, 7.3L Powerstrokes will nickel and dime you to death, 6L, yikes! Someone will probably bring up the DT-466 family. Yeah, they are good, but they were designed by International's ag division, not the truck people.
