e40d no first or reverse
Old Jan 13, 2009 | 02:47 PM
fatboyf150's Avatar
fatboyf150
ive looked all over this forum and many others and havent found what i was looking for. i have a 95 f150 351 e40d 4x4, and after changing my fluid and filter, i lost first and reverse gears in the tranny. i can hold the throttle half way open and it will slip into second gear and drive fine going into drive and overdrive. im thinking maybe a solenoid or valve stuck. as of now i havnt checked any codes nor do i have any lights flashing. any help is appreicated.
Old Jan 13, 2009 | 04:27 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Dumb question, but are you sure you filled the transmission to capacity? In other words, when you changed out the oil & filter and removed say, 12 qts, are you sure 12 qts went back in?
Rog
Old Jan 13, 2009 | 05:24 PM
fordinlinesix's Avatar
fordinlinesix
Not sure if this will help or not, but I had the same situation on a 91 4x4, C6 though, and it was doing the same thing, turned out to be one of the gears in the transfer case.
Old Jan 13, 2009 | 05:25 PM
fatboyf150's Avatar
fatboyf150
Rog
14 qts is what we put in it.
Old Jan 13, 2009 | 05:27 PM
fatboyf150's Avatar
fatboyf150
no, if it was in the x-fer case, i wouldnt have any gears. they tranny is like its not getting pressure to engage the clutch pack.
