bed questions
Old Jan 12, 2009 | 11:58 PM
73fordman's Avatar
73fordman
bed questions
does anyone know if a 78 f150 bed will fit on my 73 f250 or do i have to drill new holes in the bed to make it line up
Old Jan 13, 2009 | 12:00 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
You could take a 96 bed and put it on a 73 if you wanted. Bolt holes are all the same.
Old Jan 13, 2009 | 12:03 AM
Fordworth's Avatar
Fordworth
The framerail spacing is different between 4X4's and 2X4's in the dentside years so you will have to drill and make spacers if mixing the two.
Old Jan 13, 2009 | 12:22 AM
73fordman's Avatar
73fordman
yea
no both trucks are 2wd
Old Jan 13, 2009 | 09:07 AM
Fordworth's Avatar
Fordworth
Good deal, it's a snap.
Old Jan 14, 2009 | 11:34 AM
73fordman's Avatar
73fordman
cool beans
so no drilling required even though the bed is off a half ton and the truck is 3/4 ton
Old Jan 14, 2009 | 01:14 PM
Fordworth's Avatar
Fordworth
It should go right on.
Old Jan 14, 2009 | 01:20 PM
northeaster79's Avatar
northeaster79
the only differences in the beds are the 73 to 77 F250 4x4 high boys the frame rails are narrower.but all the 2wd trucks are the same so your safe.
Old Jan 14, 2009 | 02:48 PM
highboy1975's Avatar
highboy1975
the only difference will be one has a fuel door, the other has a cap. it's something nitpicky that is different.
Old Jan 15, 2009 | 01:39 AM
jumbofordman's Avatar
jumbofordman
Not true at all, I've put a 2wd bed on my 78 F-150 4x4.
Old Jan 15, 2009 | 02:29 AM
Don S.'s Avatar
Don S.
Note he said difference between 4x4 and 2x4, not 2wd.
Old Jan 15, 2009 | 09:22 AM
75F350's Avatar
75F350
The guy that has it absoluetly right is Northeaster79.
See the 2wd beds are the same regardless of year. The only different frame widths were from the 73-77 F250 trucks. These had a narrow frame behind the cab, so these are the only interchange is between other F250's from 73 to 77.
Later trucks 78 / 9 4x4's and 4x2's will interchange. You can even take the 1/2 ton beds from early years and interchange with the 4x4 of the later ones, these will interchange. The exception here is the fuel fillers. Doors and caps can and will be different depending on location, and early trucks may not even offer a dual tank option. (highboy1975 mentioned this)
I think everyone was correct to some degree, it just has to be explained in a little more detail.
These bed swaps are common, and really a piece of cake.
The op's beds will interchange without mounting modification.
Old Jan 15, 2009 | 03:33 PM
highboy1975
75f350 nailed it. we're all pretty much right. 75f350s answer was the best and most complete though.
Old Jan 15, 2009 | 04:15 PM
Fordworth's Avatar
Fordworth
Sorry, I didn't mean to make a lumber reference.
Old Jan 15, 2009 | 04:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Just remember you will need the fuel filler neck, hose and fuel door hardware from the 1978 as well to make it all work.
But that is all bolt on simple as well.
You should not have problems.
