When did ford start putting the 3v in the excursions? thats my bad.
Never.... Sadly 05' was the last year for the Ex. The E-series still uses the 2V. Would be nice if they would stick the 3V in the E-series but then they would have to change more than just the grill. Seems the E-series redesign over the years is a new grill, thats it.
No E-Series has the 3V engine, including the cut aways, Ford had an over heating problem with sticking the 3V in there E-Series. So you wont see it until Ford makes the next major body change to the Van.
I have a 2005 V-10 and I am in the process of replacing the fuel pump for the second time in only 26,400 miles. Is there a known defect or problem here?
Are you sure it's the fuel pump each time? Replace the fuel pump relay too, if the contacts are shot in them, the resistance WILL kill the fuel pump. I'd also check all the wiring associated with it too...
Do you run the tank until it's almost empty consistently?
The diagnosis has come from a Ford dealer both times. The first time they just replaced the pump, and it worked after that. I will talk to the service mgr about the relay however, had not thought of that. They are also replacing the sending unit this time around.
I very seldom even take it below 1/4 tank, kind of weird that way. They asked me the same thing too. It starts acting up at about 1/2 and gets worse as gas gets used up. I love this truck and want to get this taken care of, thats why I was wondering if this had happened to anyone else. I posted my own thread too after this one, said pretty much the same thing.
2000 or 2001 i don't know it's not mine it's a work truck but it has a problem at RPM. It started at about 3500, when you gave it any more then 3/4 throttle it would not accelerate, back off a little and it seemed fine but under heavy acceleration it feel like a rev limiter. That 3500 has dropped to about 2500 and that makes driving a little rough with any weight. My fuel pressure seems to be within spec(at least at idle) and i'm not popping any codes. I am still thinking fuel pump but figured i would look before i started throwing parts at it.
It is a 5-speed, it's got about 150,000 miles on it. It just had a complete tune up about 5000 miles ago
Thanks
Mine is doing the exact same thing. At 3k it hits a wall. Ive changed cop's, plugs, entire egr system, cleaned iac, air filter, fuel filter, cleaned maf, cleaned throttle body, cleaned injection system, new tps. All I havent done is checked fuel pressure, or changed fuel pressure reg and pump, and o2 sensors
I just bought this truck and its like the thing fell apart after I brought it home. Im not at all impressed with the v10 at this point. I need the truck and need it to be right so any help would be great.
Uh, check the fuel pressure under load when it "hits a wall"...
They say most won't, but maybe your the lucky one that does. Are you using a tuner on yours?
"Most 2v V10’s will not step up into Open Loop (power enrichment) at WOT and from the factory are calibrated to operate in Closed Loop which restrains power levels. By correcting this power enrichment function alone can increase power and toque from your 2V V10."
I just monitored my trucks open/closed loop status with a scanner. It does in fact go into open loop at WOT. That statement above is not true. Its a statement made by a tuner manufacturer in an attempt to sell more units.
Today while changing a leaking rad hose I noticed the at WOT the rubber line from the intake elbow in front of the throttle body to the IAC was collasping. I pulled it off and the the lines are super soft,and vac can? was full of oil. Its a dealer part @ 43.00. Im going to order it tomorow and see if that cures my "wall"
It makes sense for my truck though. Its WOT not 3500rpm where my power loss is. It also explains the puff of smoke I get @WOT. I guess combo of a bad PCV valve (replaced it) and the bad? rubber lines to the IAC created a vac from the crankcase to the throttle body. Just thinking.........thoughts anyone?
Could be if it was FOT3... out of all the V10's we have tuned this year there was only 1 PCM code that went to open loop at WOT from factory and that was PCM code FOT3.
What is your PCM code I will look it up?
