Sponsored by: Real Truck
Axle Noise :(
Old Jan 12, 2009 | 01:49 PM
PsD007.3's Avatar
PsD007.3
Axle Noise :(
ok guys i got a 2000 f350 powerstroke with auto hubs (junk), ok with the hubs in the auto position i have vacum lines disconnected i can turn the passenger side axle at the u-joint by hand, but when i come over to the drive side axle i cant turn it at all is that normal?? i'm not getting any noise at all when both hubs are in auto now on the other hand when i turn the hubs to the lock position and transfer case in neutral i am getting a very loud humming and alot of vibration once i hit 40mph?? and its defintly seems louder than normal and seems to be holding my truck back a bit?? and finally when i shift my transfer case to 4hi i get a thumping noise up front the 4wheel is working fine i just cant seem to figure out the noise?? any help would be appreciated...
Old Jan 12, 2009 | 03:26 PM
KRDiesel's Avatar
KRDiesel
Sounds like you have a shot hub, remove the hub and see if that helps.
the vibratation and thumping may be a bad universal joint, I would check that.
Old Jan 12, 2009 | 03:56 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Check the u-joints on the front d-shaft, and the u-joints on the axle shafts. When the axle is turning the vibes could be from a shaft.
You have a 2000, so spend a bit of coin to drop in Warn hubs, and at least you're hubs won't hang up again like the drivers side one is doing.
Old Jan 12, 2009 | 06:47 PM
PsD007.3's Avatar
PsD007.3
ok tore the hubs out found one was hanging up, but then tore down the whole hub assembly down and couldnt find anything at all i guess i'm down to seeing if the new warns help tomorrow or i'm taking the front shaft off and going to check all the universals anybody else have any ideas, i never thought tho i dont get a bit of chatter untill i lock the hubs i get a vibrations and when i shift the TC to 4x4 its thumping, but like i said in 2wd not a bit of noise
