Sponsored by: Real Truck
Weird cold weather problem
Old Jan 12, 2009 | 01:25 AM
F-DuceFifty's Avatar
F-DuceFifty
Whats up guys, I'm new to the FTE forums and need to pick your brains. I have really strange cold weather problem and need some help diagnosing it. When the outside temp is below say 35 degrees, none of my steering wheel controls work. No horn and no cruise control, after I drive the truck a while and the interior is warmed up they will both start working again. Let it sit for an hour and.... nothing they quit, then you have to drive around for 45 mins. before they will work again. I,m stumped any ideas are greatly appreciated. The truck is a 1999 F-250 4x4 with a 7.3L stroke.
Old Jan 12, 2009 | 03:09 AM
ReAX's Avatar
ReAX
Corrosion on the contacts? Maybe the contacts for those circuits have a bit of corrosion build up and driving (turning the wheel frequently) scrubs off just enough to make contact again. Then because of the cold, a little moisture makes it back on the to contacts and causes the freshly cleaned areas to corrode up again.
Old Jan 12, 2009 | 08:59 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The wiring is done through a clock-spring setup behind the steering wheel. Everything is direct-contact, no moving/sliding contacts whatsoever.
Sounds like the clockspring is going bad. Broken wires, move it around a bit, they start to contact again. Cold makes things shrink - heat makes them expand. As the wires in the clockspring expand from heat, they start to contact again.
But I would definitely check all the connectors involved first.
Old Jan 12, 2009 | 07:41 PM
BareBones's Avatar
BareBones
Take a hair dryer to various parts of the steering column to to narrow down where the problem is before working on it.
