interpreting codes
Old Jan 11, 2009 | 08:29 PM
plh140's Avatar
plh140
interpreting codes
I've got a 1996 f150 5.0 efi. stayed parked for over 6 months, but finally got it running. Now it throws up the codes, p1401,p1132,p1152. any ideas?
Old Jan 11, 2009 | 08:31 PM
plh140's Avatar
plh140
Oh, forgot to tell that it idles rough.
Old Jan 11, 2009 | 09:21 PM
Conanski's Avatar
Conanski
See here... TroubleCodes.net- engine & OBD2 Trouble Codes and Technical info & Tool Store.
P1401 - DPFE Circuit High Input
That's the EGR system. Ford EGR/DPFE System
P1132 - Lack Of HO2S Switch - Sensor Indicates Rich
P1152 - Lack Of HO2S21 Switch - Sensor Indicates Rich
Check fuel pressure.
Old Jan 12, 2009 | 05:48 PM
plh140's Avatar
plh140
Well, i cleared the codes and ran it for awhile. The only code that came back was p1401, dpfe. I tried unplugging the connector on it, there was no change in the idle. One of the websites said the egr system does not work at idle, so don't know if that helps. Still idles rough, but at least it runs. Is there a way to test the dpfe? thanks.
Old Jan 12, 2009 | 08:02 PM
Trublufords's Avatar
Trublufords
Pull vac. on Egr while eng is at idle.Should cut eng off or just about off.If it DOES replace DPFE--(orig is alum, replacement is plastic)make sure 2 hoses are ok- replace with same type hose if bad -rotted. If idle is uneffected when vac is applied -passage way behind egr valve is stopped up , remove egr and clean with a piece of wire and carb cleaner LOL Blue (PS idles rough all the time tap egr valve lightly with hammer- valve could be stuck open--- massive vac. leak)
