1996 Explorer XLT Throttle Position Sensor
Old Jan 11, 2009 | 04:49 PM
proudfrog's Avatar
proudfrog
How can I tell if I need to change the sensor? After my car runs about ten minutes, it has idles very run, idles up and down. But when I am driving and maintaining a constant speed, everything is ok. Sometimes, when i take my foot off the gas, the rpms drop so low that it nearly stalls out. I can watch the voltmeter sway up and down when it idles rough. If I "goose" it, it will stabilize for a bit and go back to its "loping" ways.
Old Jan 12, 2009 | 02:46 PM
marragtop's Avatar
marragtop
Normally a bad TPS will throw a code/CEL. I suggest you pull the codes. There may be a code stored even if the CEL is out.
Old Jan 20, 2009 | 02:25 PM
ripcurl94's Avatar
ripcurl94
I think there pretty cheap.. I replaced mine a couple years ago.. its easy as pie to replace..
Old Jan 20, 2009 | 06:46 PM
jsimpson's Avatar
jsimpson
sounds more like an IAC than a TPS.
