Help needed
Old Jan 11, 2009 | 04:07 PM
deereman4020's Avatar
deereman4020
Help needed
Hey everyone me and my dad decided to check if the GPR on the truck was bad but the quick connectors are troubling us. Is there a way to get them off with out breaking them?
Old Jan 11, 2009 | 04:13 PM
F350-6's Avatar
F350-6
What are you referring to as quick connectors Jacob? The nuts that hold the wires on the posts?
Old Jan 11, 2009 | 04:22 PM
deereman4020
There are some quick connectors on the valve covers. Me and my dad are thinking those are for the glow plugs. We are trying to make sure the glow plugs are good and just the GPR is bad, since the truck starts real hard in temperatures of 5* or lower.
Old Jan 11, 2009 | 04:30 PM
tdpower's Avatar
tdpower
You have to press with a screwdriver on the middle part and pull. The front 2 and back 2 pins are for the glow plugs. They should read around .6 ohms, no more than 2.
Old Jan 11, 2009 | 04:35 PM
F350-6's Avatar
F350-6
Yes those are a pain to get off. Once you press down on the center release tab, it sometimes helps to take a very small screwdriver and use it to help pull the plug out of the connector. Robin has a picture of this somewhere. I'll see if I can find it for you.
Edit: Found it
Old Jan 11, 2009 | 04:55 PM
hucka1a's Avatar
hucka1a
Jacob here is the pin out for the harnesses.
uvc pin out
Pin Out at the valve cover to test them,,
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
***The injectors fire with a 115VDC signal from the IDM do not pierce to wires to test.***
Ohm between "I" and "C" to test the injectors, should be less than 5.0 Ohms
To check glow plugs Ohm between "G" and battery ground should be between 0.1 and 2.0 Ohms
Old Jan 11, 2009 | 05:29 PM
deereman4020
Thanks guys. This really helps. I will keep you updated if it is the glow plugs or the GPR, that's giving me troubles.
Old Jan 11, 2009 | 05:30 PM
hucka1a's Avatar
hucka1a
Good luck Jacob.
Old Jan 18, 2009 | 12:40 PM
deereman4020
Hey everyone I tested the GPs and the #s I got were(back to front) Right side: 068, 120, 067, and 115. Left side: 122, 126, 170, and 180. The meter I used didn't show a decimal point anywhere so I am not certain if the ohm levels are with in normal specs.
Old Jan 18, 2009 | 02:15 PM
tdpower's Avatar
tdpower
Assuming your ohm meter is working good you have bad glow plugs. Motorcraft are probably the best. I would stay away from autolite.
Old Jan 18, 2009 | 02:30 PM
deereman4020
I thought the Ohm level had to be between 0.1 and 2.0 ohms. I am pretty sure the meter is working correctly.
Old Jan 18, 2009 | 02:35 PM
tdpower's Avatar
tdpower
re
Yes, that is correct. All your readings are out of spec.
Old Jan 18, 2009 | 03:08 PM
deereman4020
When I had the meter set on a lower Ohm reading level when I measured the right rear glowplug the Ohm reading was 06 or something similar(I can't remember cause I didn't write it down.) I'll try testing the glowplugs again with a different meter. I highly doubt that all of the glowplugs are shot.
Old Jan 18, 2009 | 03:27 PM
tdpower's Avatar
tdpower
My meter is auto ranging. I doubt all of yours are shot that is why I questioned the meter or as you pointed out a setting.
Old Jan 18, 2009 | 03:44 PM
deereman4020
Me and my dad, between the 2 of us have almost no clue when it comes to electrical stuff. I don't know the brand of meter we used but I can find out.
