I was in a performance/racing parts store by me and saw some exhaust manifolds, or the begining of them anyway. They were just the thick flange with 4 3" long pipes coming out. I guess they're for making your own headers or just adding 'j' pipes to and sticking them up thru the hood.
So, since I need fenderwell headers for my 78 460/4x4 @ $400 a set, I thought I'd get a pair of these flanges and make my own for a lot less.
Has anyone seen these or done this? Can you use regular exhaust pipe or should it be thicker wall stuff? Or, have I just watched too many episodes of "Monster Garage"?
I've made an entire set of headers from scratch minus collectors. (They didn't make headers for the paticular engine swap i was dealing with). If you have access to a tubing binder i don't think it would be very hard. I however,not having access to a tubing binder, had to miter all the angles right from the flange to the collectors. this proved to be a very big headache and I wouldn't do it again. they turned out okay, but there was alot of wasted material dew to mistakes when making compound angles. I used regular 1 7/8 exhaust pipe and painted it with VHT header paint. They've been on the vehicle 4 years now and I haven't had any problems.
I believe that the time and money you spend to build a set of headers the "correct" way would be better spent on the other headers (L&L's)
To build them right, get the flanges that have the short stubs welded to them already ($138 in Jegs), a lot of mandrel bent pieces of pipe in the size primary tube you want, most likely 1 7/8" (cost varies on how many pieces of tubing you get but most likely around $150) Then send them out to be coated so they don't rust right away ($150-$200). Last, but not least, is your time to build these things (many,many hours of frustration, measuring, cutting and lots of welding, not to mention more pre-bent tubing if you mess up a cut) If there is a header available for the vehicle/engine combo, I'd buy before I built a set. This is not to say that I wouldn't ever build a set of headers, I'm concidering this for my project Ranger, this is only my opinion.
Rcmgiasson,
I don't have a bender either and planed on mitering/welding the bends (I did my whole exhaust system that way [link:http://www.brayarch.com/~kevin/truck/jan2aug02.html:see it here]). I'd love to see some pics if you have any.
Where would I look for the collector?
Mike,
I hear what you're saying, but I can't justify the $400 l&l's at this point. The flanges are in the $70-$80 range at this place and I can get two 10' pieces of pipe for about $10-$15 each. Finding the time is the tough part, but I'm not in a hurry.
BTW, that ranger looks awesome! What size are those tires?
I have 3 vehicles with exhaust done that way (mitering and welding) and thats why i thought i could build headers farily easily. Not true, after banging my head against the wall I finally had to get my dad to help. he's a journeymen pipefitter and welder and even he was scratching his head at times. I don't recommend doing it this way. As for the collecters I cut them off a good set of headers that had cracked around the flanges. i don't have any pictures on hand and I don't have a digital camera. However I will take some pictures with a normal camera, but it will take some time to get them developed, and I'll see if I can borrow a friends scanner so i can post them.
Kevin, thanks for the copliment on the Ranger. Those tires are 14.3/26, about 53" tall. For collectors, don't know where to find them. Maybe that shop that has the flanges can help on that. If i find some, I'll let you know.
