Spark plug heat range
Old Jan 11, 2009 | 02:02 PM
bigcountry1009's Avatar
bigcountry1009
Can someone explain plug heat range and when would you change what you have?
Old Jan 13, 2009 | 11:18 PM
fordeverpower's Avatar
fordeverpower
if you have issues with heat, denotation, high compression, or highly modified engine, or racing you may want a step or two colder plug. If you live in northern canada, you might want a hotter plug to keep engine efficency.
Old Jan 14, 2009 | 07:34 PM
bigcountry1009
Ok, but I'm looking for a more technical definition. I guess I'm wondering what happens when you change heat range. I know that physically the insulator get progressively larger/smaller as heat range goes up/down, but I don't understand what actually happens to the ignition process and what issues/problems that may cause.
