Help With Uncles SD
Old Jan 11, 2009 | 09:24 AM
JethroF250's Avatar
JethroF250
Help With Uncles SD
ok need a little help guys. wanted to stick in the forum where i know everyone lol. my uncle called yesterday and asked me why his truck aint startin good. i know its a 7.3 SD dont know exact year. hes havin trouble startin it in the cold. he said the GP Relay is good or so he thinks and his relay for intake heater is bad. as far as i can remember the intake heater dont work unless you get to extreme cold like negatives. am i correct? what all should i check for on his rig? relay put out, gp, etc? how would i check them? any help is appreciated he uses the truck for his business so he wants me to see if i can figure somethin out in a timely manor. thank for any help guys
John
Old Jan 11, 2009 | 10:52 AM
KevinC.'s Avatar
KevinC.
Ok, if the gp relay is good (how do you know?) But the gp relay is also easy to test. Check the resistance on the gp's. Pull off the harnesses that go into the valve covers. With key off, check the outermost lugs on each UVC harness, these are the gp wires. Using an ohmmeter to check them, they should read .1 to 2.0 ohms. Replace ones that read higher, but if only a couple read high I would change them all because you don't want to have to pull the valve covers again.
Old Jan 11, 2009 | 11:50 AM
JethroF250's Avatar
JethroF250
ok. i told him the relay could be fine but may have some bad gps. he tested it himself (relay). how do i check the relay?
Old Jan 11, 2009 | 01:06 PM
KevinC.'s Avatar
KevinC.
The GPR has 4 wires, the black/orange is your supply. Use a 12 volt tester on that wire, there should be constant power, key on or not. Now turn the key to start, you will hear it click, when it clicks on test the brown wire, if it has power the GPR is good. Most likely only gp's though.
Old Jan 11, 2009 | 03:00 PM
JethroF250's Avatar
JethroF250
ok thanks alot Kevin i will prob work on his truck this upcoming week if i aint workin and work for him is slow as well
Old Jan 11, 2009 | 03:44 PM
KevinC.'s Avatar
KevinC.
Your welcome, everyone on here helps me out so when I see somethin I've already done I gotta help out with it. Good luck with it and let me know how it turns out.
Old Jan 12, 2009 | 10:09 AM
superduty4x4's Avatar
superduty4x4
The IAH will not help a cold start... GP's or GPR for sure.
