hi bill i need your help on these part #s to identifie parts for sure
d7tz-1042-430-a mouldings
d7tz-1042-436-a connectors
if i am reading this right it says these are the rubber trim for the rear 1/4 windows for a 73/79 supercab with stationery windows would this be correct?
thank you in advance for your help regurds joe
1974/79 F100/350 Super Cab Qtr Glass W/strip-Fixed
d7tz-1042430-a mouldings
d7tz-1042436-B connectors
if i am reading this right it says these are the rubber trim These parts are chromed plastic, for the 1/4 glass weatherstrip-see below.for the rear 1/4 windows for a 73/79 supercab with stationery windows would this be correct?
The Super Cab uses the same plastic chrome moulding and joint clip for the quarter windows, that the back glass uses. This plastic moulding is flexible, and must be cut to fit.
D7TZ1042430A .. Quarter & Back Glass Plastic Chrome Moulding / Available from Ford
MSRP: $41.95 / FTEpartsguy.com price: $30.20
D7TZ1042436B .. Quarter & Back Glass Plastic Chrome Joint Connector Moulding / Available from Ford
MSRP: $3.59 / FTEpartsguy.com price: $2.58
Super Cab fixed quarter window: The one piece rubber weatherstrip fits between the glass and the body. This w/strip has a groove in it..for the plastic moulding to fit into.
2) D4TZ1029904A .. Super Cab Quarter Glass Weatherstrip-Use with Fixed Window / Obsolete
DENNIS CARPENTER in Concord NC has 27 = 704-786-8139
hi bill thank you very much for the info checked the sponser also and will contact them this week for shipping quote to canada i have spare rear windows [stationary glass] and rubber just want to have complete set just in case again thank you as you are a great asset to any ford fan regurds joe
FTEpartsguy is Ed Olson, parts manager of PARR FORD in Bremerton WA.
That same plastic trim was used on 1973/96 F100/350's.
