Special plug socket?
Old Jan 10, 2009 | 02:46 PM
Texasplumr's Avatar
Texasplumr
I need some advice here. 1995 F-150 4X4 5.8
I searched the forum and can't find another post like this so here goes.
I can't get a socket on the #4 spark plug. The socket hits the exhaust maniflod and won't go all the way on. I broke the old one in half and then the socket fit on it just fine and was able to remove it quite easily.
I started the new one by hand easy enough but once hand tight the socket won't go on the nut part (whatever you call it). It goes right up to it but hits the manifold.
I don't really want to run it hand tight and none of the parts houses seem to have ever heard of this happening before. I'm positive the I didn't cross thread it.
Any suggestions would be appreciated. I have time since I'll now be replacing all of the plastic vacuum lines that I broke.
Thanks!
Russ Lane
Austin, Tx.
Old Jan 10, 2009 | 03:05 PM
quicklook2's Avatar
quicklook2
thin wall spark plug socket is what you need.
craftsman or other good quality.
while at parts store also buy a spark plug thread cleaner and ream the hole first.
Old Jan 10, 2009 | 04:03 PM
Texasplumr's Avatar
Texasplumr
Thanks for the reply.
I did get it tight but just took an old socket and ground it down till it fit.
The suggestion about cleaning the threads is a great one too. I always blow the bank off before I remove any plugs and being a plumber by trade, I have found a copper fitting brush to be ideal for cleaning the threads.
Thanks again!
Russ Lane
Austin, Tx.
Old Jan 10, 2009 | 04:46 PM
quicklook2's Avatar
quicklook2
the tool is like under 5 bucks and is well worth it for these fords that have a history of snapping plugs when they are stuck.
