nos help
Old Jan 10, 2009 | 05:41 AM
lew52's Avatar
lew52
nos help
i have a 95 f 150 5.0 want to run a wet nos system on it ..Any one who has done it or knows about it Thanks
Old Jan 10, 2009 | 08:40 AM
BigBlueOx's Avatar
BigBlueOx
Ive never done NOS on an F-150, but I have on other vehicles. What do you want to know and how much more power do you want? A wet system is easy. Its the multiport that gets difficult.
Old Jan 10, 2009 | 09:32 AM
lew52's Avatar
lew52
Ya were looking for 150 hp Its a 302 HO .. Out of a mustang... But were running the truck intake & mass air...Want to use a wet kit dont think they make a manifold spry bar plate... We were going to use the soft plume nozzle & put it in the intake tube ??? Ive heard diferant ways to do it ??
Old Jan 13, 2009 | 11:51 AM
lew52's Avatar
lew52
This is the way were going to do it... Going to use 2 nozzles since we have the dual throtle body... One 75 shot in each intake tube .040 nos jet .028 fuel ... That should put us on the rich safe side...Then tune it with a wideband... Going to run RPM window swith...on at 3800 off at 6000... were shifting it at 5900...rev limiter set at 6200... Were going to use steering wheel button as activation swich.... When we get done with a run we can let off the button & let it clean out before shut down...Also running a MSD ign reatard box to retard timing while shooting... Smart or Stupid ???
Old Jan 13, 2009 | 12:27 PM
BigBlueOx's Avatar
BigBlueOx
start small and keep it safe. Progress slowly. Sounds like you've done some homework. What else is done to the truck and what is its main use? You may also want to search mustang forums to maybe get a base map for your setup. Other wise it sounds good to me, but there is always the fine tuning. What looks good on paper doesnt always work that great. Keep us posted, I'm interested.
Old Jan 13, 2009 | 12:55 PM
lew52's Avatar
lew52
Thanks !! ya igot a lot of info from the mustang fourms... They said the same thing just easy at first... idont think were going any more than 150... shot...Its not a daily driver Week ends & strip... Its a 302 HO out of a mustang... 351 dooe heads..e303 roller cam..1.72 roller rockers..edelbrock intake...80mm pro m mass air calibrated to a matched set of 30# injectors...long tube headers .. 2-1/2 tru flowmaster 44s...msd ignition..dyno tuned computer chip..e fans...underdrive pullys...lots trans .. rear...syspension work .. I will let you know how it gos Thanks !!
Old Jan 13, 2009 | 01:10 PM
rostena's Avatar
rostena
Sorry to go off topic here, but I just gotta ask. lew52, how much HP and TQ does your truck produce?
Old Jan 13, 2009 | 01:34 PM
MustangMatt96GT's Avatar
MustangMatt96GT
150 shot even on the forged 92 factory pistons that came in the mustangs is pusshing it... run a 100 shot, and honestly i would not do two foggers... run one fogger, about 10 inches from the TB and make it so the two intake tubes go into 1 tube.... 2 foggers you get lean spikes more frequently because of the distance that the fuel and the nitrous is going especcaqlly with two foggers....
you could always use a single TB off of a mustang (best way IMO)
Old Jan 14, 2009 | 04:23 AM
lew52's Avatar
lew52
Rear wheel hp 240....Rear wheel tourq 300...
Old Jan 14, 2009 | 04:50 AM
lew52's Avatar
lew52
Thanks for the advice !! i think we will tone it down to 100....if i run a single fogger it would have to go in the single intake tube before it splits to two thats about 18 inches from throtle body....cant use mustang tb because were using edlbrock truck intake... thats where we get the tourq..from the pro m mass air it has a single intake tube about 18 in long..then it splits to two ..thats 12in long then the duel tb... so if we use two fogers we can puy them 10in away.....soft plume foggers...like all the advise...want to be safe here Thanks..
