Ranger trouble
Old Jan 9, 2009 | 07:51 PM
crittman's Avatar
crittman
Ranger trouble
I have a 1998 Ford Ranger with the 4 cylinder engine. It has sat in the garage for the last year and has not been started. I put in a new battery, fresh gas and replaced the fuel filter. It turns over, but wont start. When I spray started fluid in the intake, it runs for a few seconds, then stalls out. I was thinking the fuel pump might have went out or the IAC valve gone back. Any help would be appreciated..
Old Jan 9, 2009 | 08:01 PM
73f100shortbed's Avatar
73f100shortbed
Check for fuel pressure since it runs on starting fluid. When you turn key on you should hear pump run for 3 seconds if it is working.
