Sponsored by: Auxito
Electrical Connections Pt.2
Old Jan 9, 2009 | 04:17 PM
nbafreak2007's Avatar
nbafreak2007
Hi All,
I Have a 97 F-150 XLT 4.2LT. 5spd, we recently removed the whole dash to replace the heater core and blend door, this was before i relalized we did not need to take off the entire dash to do so. After we reinstalled the dash and turned the engine on we realized that the blower motor and the criuse control were not working. We have tested the 40 AMP fuse in the engine compartment and it test fine. Maual shows that we should have 10,000+ ohms but we do not. After looking underneath the steering column we found two remaining electrical connectors that were not connected to anything (see pictures below) and cannot find a mate for them, and were wondering if anyone knew what they were for and where they go. Any help would be greatly appriciated.
Old Jan 9, 2009 | 04:51 PM
KingRanchMan02's Avatar
KingRanchMan02
The black connector has three circuits and the gray connector has two. What color are the wires in each of these connectors?
You said that the only thing that doesn't work is the cruise control and the blower motor? The black connector is possibly the brake pedal position switch connector. The other is still a mystery because it doesn't fit in the blower circuit. Good luck!
Old Jan 10, 2009 | 01:47 PM
nbafreak2007
The color of the wires going to the connectors are for the black connector green, black and an olive green color. For the Grey connector green with a black stripe and a red wire, i will check to see if one fits the brake pedal.
