transmission lines
Old Jan 9, 2009 | 02:01 PM
chas4x4's Avatar
chas4x4
transmission lines
Is there a big difference between rubber gas line and rubber transmission lines?I need to replace a piece of cooling line will it make a difference.
Old Jan 9, 2009 | 08:55 PM
ctubutis's Avatar
ctubutis
In my experience, all transmission cooling lines are steel; this is to avoid the ensuing fire
that occurs when a dry-rotted rubber hose blows and tranny fluid starts gushin' all over the
exhaust. If you've got rubber hose, I'll bet a PO put it into place, it didn't come from the
factory that way.
Old Jan 10, 2009 | 11:30 PM
stuart1's Avatar
stuart1
use a rubber line that specifies for cooler line only.
Do not use gas or air hose.
