return lines
Old Jan 8, 2009 | 09:21 PM
big blue diesel's Avatar
big blue diesel
Cool return lines
does anyone have a picture/ diagram on how the injector return lines should look. i replaced them as they were in the truck but i 2 that continue to leak, they hook together2nd from the back both sides.
Old Jan 9, 2009 | 04:11 PM
PLC7.3's Avatar
PLC7.3
Is your truck 6.9/7.3 N/A or turbo equiped....... Put up a signature with some truck info..... Please!!
The turbo equipped crosses forward of the intake the N/A crosses at the back 2 normally.
Old Jan 9, 2009 | 04:14 PM
PLC7.3's Avatar
PLC7.3
Check this pic........ N/A Engine
Clean Engine - TheDieselStop.Com Photo Hosting
There MUST be sufficient slack between the cap/hose on opposite sides for the hose to lay flat.
Old Jan 9, 2009 | 06:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Or is it possible the throttle linkage is hitting the cross over line?
Old Jan 9, 2009 | 06:44 PM
Franklin2's Avatar
Franklin2
Return lines are red.
Old Jan 9, 2009 | 07:08 PM
BombThreat's Avatar
BombThreat
i replaced mine along with the caps and the 2-3 on the back passenger side still seep fuel... any ideas?
Old Jan 9, 2009 | 10:52 PM
Franklin2's Avatar
Franklin2
Did you grease the o-rings before installation of the caps? I used my old caps and didn't have any problems.
Old Jan 11, 2009 | 02:17 AM
94 Turbo's Avatar
94 Turbo
I replaced mine with just the o-rings the first time and a few still seeped fuel. So, just last month I replaced the again and used new caps. I had to reuse the two middle caps on both sides because they where different than what came in the kit. But I didnt use any grease and I have had no problems at all with leaking this time. I may be wrong, but I heard that the new diesel fuel will make the o-rings and return lines get hard and start leaking and that if you buy sulffer replacement to add to the fuel, it will make them last alot longer.
Old Jan 11, 2009 | 02:46 AM
Dodge/Cummins's Avatar
Dodge/Cummins
That's the best signature picture I've seen.
Cute kid!
Got 4 of my own from 2-8 years old, of course mine are cuter! LOL!
Old Jan 11, 2009 | 11:49 AM
94 Turbo's Avatar
94 Turbo
HaHa! Thanx! Yeah mine are 3 and 7. Both are boys, lucky me!
Old Jan 11, 2009 | 12:54 PM
Franklin2's Avatar
Franklin2
When you slide the caps on, the o-rings will have a tendency to want to "roll" up out of the groove. Grease, oil, diesel fuel, anything that will lube the o-ring and make it slippery, along with wiggling the cap back and forth while installing it, will help the o-rings seat and seal properly.
Lubing o-rings is good practice whenever you are doing mechanical work on anything that requires them. Just make sure the lube is compatible with the fluid that you are sealing.
Old Jan 11, 2009 | 05:27 PM
Dave Sponaugle
Yes and it is easy to nick the O rings when you install them.
I grease mine and the injector top before I even start trying to put the O rings on.
Seems to help them slide on without catching and decreases how far they fly if the slip off, well sometimes it does anyway.
Don't know if I am getting fumble fingers or what, I usually manage to lose at least one when I change mine.
Old Jan 12, 2009 | 08:59 PM
big blue diesel
Cool reurn lines
franklin2 is that also for turbo idi
Old Jan 13, 2009 | 01:31 AM
Dave Sponaugle
That was for the NA engine.
The only difference is the turbo engine moved the cross over line up away from the turbo downpipe.
Normally the turbo motors have a single nipple return tee on the rear passenger side injector, return line runs toward the front.
That keeps the return line away from the downpipe.
How the lines run is not critical.
The only thing you have to have a return line connection to each injector, the IP and the fuel filter.
Old Jan 14, 2009 | 10:29 PM
big blue diesel
Cool return lines
my return lines do have a single nipple on the pass side like you sadi. the part i dont like is that the single line from the ip runs into the return lines not the return to tank line. so is it possible that the lines get pressured up and thats where i get the leak. the cross over is on the 3rd from the front.
94 idi all stock, 259k
Mitch Bellinger
Dec 8, 2016 08:45 PM
Suomi Powerstroke
Nov 16, 2009 10:10 AM
LIGOOMBA
Nov 10, 2008 08:39 PM
Charger73400
1983 - 2012 Ranger & B-Series
Oct 11, 2007 01:19 AM
2New2Fords
Sep 29, 2006 05:54 PM
