Leaking motorcraft carb
Old Jan 8, 2009 | 09:08 PM
R75CS's Avatar
R75CS
I have gas leaking from the pump diaphragm assembly cover of the motorcraft carb,2BBL,360,75,auto.Is this easily repairable,or is a new carb in my future? Thanks
Old Jan 8, 2009 | 09:36 PM
Old93junk's Avatar
Old93junk
You mean the Accelerator pump? If so, 4 screws, 1 spring and $3.99 for a new diaphragm. Thats pretty much it.
Old Jan 13, 2009 | 03:12 PM
R75CS's Avatar
R75CS
Thanks Old93junk I haven't had a carbed vehicle for a long time.I was using the part description from a diagram.Accelerator pump it is. I will get to it tomorrow.If you have any tips I would be glad to hear them,changing fluids and plugs is about my level of skill.Thanks again.
Old Jan 13, 2009 | 06:09 PM
fmc400's Avatar
fmc400
MSEE
It's not a bad job, just make sure you don't lose the spring that's under the diaphragm cover. After you get it installed, pump the throttle a couple times to re-prime the accelerator pump.
Old Jan 15, 2009 | 10:59 PM
R75CS's Avatar
R75CS
Thanks for the help,kind of nice not having gas leaking onto the engine.
lalberts
Dec 5, 2016 08:47 AM
Chayse
Dec 4, 2016 06:00 PM
Rollie 1
Oct 18, 2014 11:51 PM
irydasteelhorse
Apr 15, 2014 12:42 PM
vls
13
Dec 11, 2011 05:34 PM
