Transfer case....
Old Jan 8, 2009 | 07:33 PM
jamie7375's Avatar
jamie7375
Transfer case....
does anyone have a good thread on changing the transfer case fluid?
Old Jan 8, 2009 | 08:34 PM
dc3655's Avatar
dc3655
No threads, but it was an easy change. I just drove up onto my blocks on a slanted up driveway which really put my front end high in the air and allowed most of the oil to drain out. Then I filled the oil up to the filler hole, capped it, backed down onto flat ground and then topped it off. I got everything out that I could and it used exactly 1 qt. All I can say is that you should use a synthetic oil since it's only 1 quart.
Old Jan 9, 2009 | 09:18 AM
rock_doctor's Avatar
rock_doctor
It is a normal transfer case. So any instructions you can find on the web will work fine. Drain through the lower plug and refill through the upper plug (plugs are in the back facing side of the case where the output shaft comes out). I used 2.5 qts of Mobil 1 ATF or you can use the SP fluid for the trans. It is good to change the tcase the same time as the trans fluid.
Old Jan 9, 2009 | 11:45 AM
3000 FPS's Avatar
3000 FPS
I agree with the rock_doctor. I burnt a transfer case up once and synthenic does make them run cooler.
Old Jan 9, 2009 | 09:28 PM
slowmans's Avatar
slowmans
I changed mine this summer and it took 2 quarts, you may want to check your level.
Old Jan 10, 2009 | 06:36 AM
dcaddi2's Avatar
dcaddi2
Welcome to guzzle's Transfer Case Fluid Change Web Page
Old Jan 10, 2009 | 12:26 PM
dc3655's Avatar
dc3655
slowmans, you're right, it was 2 quarts on the dot for me. It's been so long that I forgot. It's easy though because you just fill it till it begins to come back out the filler hole.
Is everyone changing it every 30k miles?
Dcaddi2, that's a good link! That's the link I'd found years ago when I initially did my transfer case oil change.
Old Jan 10, 2009 | 02:55 PM
skunkoffroad's Avatar
skunkoffroad
yep 30k every time I do the trans.
