5 speed transmission interchangability
Old Jan 8, 2009 | 07:14 AM
kelro's Avatar
kelro
Reverse gear is out on my 95 F350 4wd with a diesel. When I put a pto drive on it last spring, the drive people told me that I had a gas gear in there. I assumed I had a complete tranny off of a 460? Do the transmissions interchange between the 2 engines or are there signicant differences?
Thanks
Kelly
Old Jan 8, 2009 | 07:50 AM
Talyn's Avatar
Talyn
Last I knew the 351 and the 7.3 were not interchangeable. However, I've do not know about one off a 460 bolting up to a 7.3.
Well, unless you can change bell housings.
Old Jan 8, 2009 | 09:05 AM
Cuda_jim's Avatar
Cuda_jim
Diesels are an animal all by them selves, gasser trannys will not bolt up.
Old Jan 8, 2009 | 09:09 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Too bad you're so far away. I've got a spare ZF5 from a PSD sitting in my barn that I really don't need or want.
Old Jan 8, 2009 | 09:48 AM
kelro's Avatar
kelro
I would be interested if we could get it shipped down here. Zip code is 66952.
