Inductive Heat Flash
Old Jan 7, 2009 | 08:42 PM
FORDSDOWNER's Avatar
FORDSDOWNER
Has this flash been incorporated in the newer models trucks that roll off the factory floor or is it soley based on request?
I had my truck flashed mid last year as I was purchasing it, but I do not know if the typical flash contains the Inductive Heat code...
Old Jan 8, 2009 | 12:26 AM
rollerstud98's Avatar
rollerstud98
Yes you'll have the inductive heat flash then, I got mine done early 2008 and it was the inductive heat flash.
Old Jan 8, 2009 | 06:56 AM
BowTieHatr's Avatar
BowTieHatr
its possible. wait for a COLD morning, when you go start the truck and fire off the glow plugs, the injectors will buzz the entire time the glow plug light is on. when the light goes off, the buzz goes off.
Old Jan 8, 2009 | 05:01 PM
FORDSDOWNER
Thanks for the replies.
When temps where down in the 30's and I started the truck (after the glowplugs cycled twice the recommended time) it would be choppy for the first second or so and clear right up. What I do is let it idle for 30 or so seconds before driving off. After the choppyness clears up, you can faintly hear and feel some fluctation in the idle though.
Normal per say or be expected given the condition?
I'll check for the buzz too. I think the only thing I have been hearing is the vacuum pump
Old Jan 8, 2009 | 07:28 PM
Sarge261's Avatar
Sarge261
BTH,
Thats the answer I have been looking for. So the injectors will buzz with the Inductive Heating Flash. Mine have stopped buzzing when cycled. Its in the shop now and needs 1 injector...so maybe the FICM is at fault also.
Sarge
