Puffs Smoke Like a Steam Locomotive
Old 01-07-2009, 07:38 PM
conifers4's Avatar
conifers4
conifers4 is offline
Well, I just brought home my new to me 2003 6.0 PSD 250 the other day, next morning started her up, got her warmed up and took a ride on the highway. Everytime I accelerated the truck would buck and make a strange engine noise that coincided with large puffs of black smoke that came out like a steam locomotive. From everything I read here and from what the dealer told me when I went back ranting points to injector problems. Truck is now going on its second day in the shop and am awaiting results from the Ford dealer. Any ideas on any OTHER reasons this could happen? Trying to educate myself as best as possible and have been reading as many posts as possible. Thanks in advance!
Old 01-07-2009, 07:44 PM
The6.0MAN's Avatar
The6.0MAN
The6.0MAN is offline
Congrads on your new truck. Possible checks are EGR, Injectors, turbo vains opening and closing properly, H2O in the fuel.
Old 01-07-2009, 07:50 PM
conifers4's Avatar
conifers4
Thank you, not off to a great start with it. Had it home for less than 24 hours before it went back. It only has 41,000 miles but I know its been sitting on their lot for quite awhile. Could the fact that it was sitting for an extended period of time cause the injectors to clog.
Old 01-07-2009, 08:14 PM
The6.0MAN's Avatar
The6.0MAN
If anything is "clogged" it would be the EGR valve. Usually the culprit in the symptoms you described.
Old 01-08-2009, 12:20 PM
conifers4's Avatar
conifers4
Update, I stopped by the dealer and they told me there replacing one of the turbo fans. They say it was warped or bent. Why do I seem not to confident?
Old 01-08-2009, 12:29 PM
UGA33's Avatar
UGA33
UGA33 is online now
A 6.0L that sits to long will have "Lot Rot." This is where the vanes in the turbo will rust and become stuck and can display the symptoms you described. Some brand new 6.0L's that were purchased had to have new turbos due to them sitting at the lot to long and the vanes rusting up.
Old 01-08-2009, 02:06 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
Do not worry about it, After they go through it, You will have a happy truck, I have over 150K on mine.
Old 01-08-2009, 02:57 PM
conifers4's Avatar
conifers4
When I went to pick up the truck this is exactly what they told me. Thank you for your post as it has put my mind at ease.
Old 01-08-2009, 02:59 PM
conifers4's Avatar
conifers4
I sure hope so, since I'm new to diesels I can't even imagine having 150k on an engine. Seems to be running soooo much better now.
Old 01-08-2009, 04:02 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
150k Miles are not a big deal, the enging is rated for 400K + before rebuild.
If you take care of it
Old 01-08-2009, 08:13 PM
dirtleg's Avatar
dirtleg
dirtleg is offline
Not to worry. When I test drove my truck the turbo vane controller groaned and rattled for about 10 seconds one time. It was the only potential "deal breaker" I found. I read on here what the problem could be and had the answer before the dealer had figured it out. They said the same thing. Vanes slightly stuck due to sitting. A very common problem.
Well it's been almost 3 months and 6,000 miles with no further issues. Truck has 76,000 and runs great.
Good luck and I hope you enjoy yours as much as I am enjoying mine.
Old 01-08-2009, 10:58 PM
04redstroker's Avatar
04redstroker
04redstroker is offline
I feel your pain. I just bought an 04, had it a week and it already needs a motor.
Old 01-08-2009, 11:20 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Now that sucks, you still in warranty? My motor, turbo and egr cooler have all been here for the life of the truck, 220k km's. It is in getting the tranny overhauled right now though, putting in a heavier duty torque converter as well as a transgo shift kit. I'm not in warranty obviously which kind of sucks but at the same time its better since I'm upgrading the parts now.
Old 01-08-2009, 11:21 PM
brickie's Avatar
brickie
brickie is offline
What is wrong with the motor that it needs to be replaced?
Old 01-09-2009, 11:40 AM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
yea, that is what I am wondering. Most states have a "implied" warranty of 15 days if bought from a dealer.
Quick Reply: Puffs Smoke Like a Steam Locomotive
