6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Job numbers on 08's
Old Jan 7, 2009 | 11:18 AM
250ssd's Avatar
250ssd
Job numbers on 08's
Hey all,
I am buying a 6.4 I want to know what the difference is in the job #'s. I am looking @ a truck that was built on 05/07. what job # is it? Is there something I need to watch out for. For the record this is a Canadian truck, If that makes a differance???
Thanks
Old Jan 7, 2009 | 11:43 PM
powerstroke1350's Avatar
powerstroke1350
Thats a job 1 truck. They had the most Radiator and engine problems. Get an Oasis report on it.
Old Jan 8, 2009 | 01:51 AM
pilotshot's Avatar
pilotshot
250ssd
All Canadian Ford 6.4L PSD's are made in USA. Mine was built at KTP. Canadian trucks have Kilo speedos and daytime running lights. The revised Canadian warranty includes a unique powertrain warranty which extends coverage for Transmission, four wheel drive components and rear drive components for 160,000 KMS / 5 years which is better than the US warranty.
I have a job #1 built in Jan 2007. I have been keeping up with Ford recalls and re flashes. You should have the Customer Satisfaction Program (CSP) 08B06 which installs a Cooling Systems Venturi Tee Kit to prevent reverse flow from the degas bottle to radiator and CSP 08B07 to reflash the PCM and IC. If so, you should have no problems with a job #1 truck. Both are under warranty claim with Ford of Canada. Before purchase, ask the Ford dealership for the oasis report on all repairs done to the truck. You can also get the oasis report in this forum with a Vin Number.
I also installed a Job #2 air dam on front of truck. It is 6 inches deep rather that about 2 inches on a job #1. It give a slightly better fuel mileage and water spray control.
I have 39000kms on my truck and hasn't had a thing go wrong so far. It is the best truck I have ever had.
Old Jan 8, 2009 | 10:38 AM
senix's Avatar
senix
took this from a thread awhile back:
January 07 - June 07 = Job #1
July 07 - December 07 = Job #2
January 08 - June 08 = Job #3
Old Jan 8, 2009 | 12:48 PM
250ssd's Avatar
250ssd
Thanks to all for the info. I also want to install the Saprtan tuner, S & B, and delete pipe. Has anyone out there done all these mods to a Job #1 truck? How did it handle the Tune?
Old Jan 8, 2009 | 02:49 PM
senix's Avatar
senix
someone will post soon that can advise on those. Be aware that you run the risk of voiding the warranty if you do that.
Old Jan 8, 2009 | 03:14 PM
kane gray's Avatar
kane gray
Originally Posted by 250ssd
Hey all,
Thanks
Is this a new truck you are looking at? It would have been at the dealer for quite a while. If that matters
Old Jan 8, 2009 | 03:53 PM
250ssd's Avatar
250ssd
No, The truck has 70,000 km on it. It will be new to me but it is a used unit.
dbross
2009 - 2014 F150
Oct 12, 2011 07:32 AM
BigRed1
Aug 16, 2008 06:22 PM
true4.2
Jan 18, 2008 04:12 PM
lee3
Nov 29, 2007 10:51 PM
DaveinSoCal
May 17, 2004 03:53 PM
