Blinking on the shifter. Been having some problems with truck not turning over with the key now the 2004 f250 SD tow/hull light blinks on the shifter . Please help if you can.
blinking on the shifter means a trannie related problem. not turning over could be a hundred things. need more info. does it have an auto starter, does it work/not work dry, cold, wet, hot. does it make any unusuall noises. how many ks? whats it used for? etc...
Auto starter not working either. No unsuall noises. Not sure about ks? if it means Kill switch none. It just started not turing over with out the key have to jump the starter to start it.
the very first thing you have to do is check all the remote starter, wiring and function. then see if the starter is getting a signal, the small wire, when the truck wont start. if it is not getting a signal then id look at the shifter or the trannie issue to see if the truck thinks its in gear or something. check the easy stuff first, wiring etc. if your able to disable the auto starter.
I start checking out the truck and couldn't find anything wrong. Come to find out the cooling fan is bad and it keep the truck from starting.... Crazy huh?
Picked up my truck yesterday and it was the cooling fan clutch that made the truck not turn over by the key and the trans not to shift. All is well now truck runs great!
