Sponsored by: Real Truck
Low Range not engaging
Old Jan 6, 2009 | 11:43 AM
kissingbug1978's Avatar
kissingbug1978
Exclamation Low Range not engaging
I'm the proud new owner of a 2004 F250 Supercrew with a 6.0L PSD. Everything works except it won't shift into low range. From what I've read on here these trucks have issues with the ESOF if not used on a regular basis. I'm thinking its probably some thing simple, maybe a fuse or relay but seeing as how it didn't come with the owners manual I don't know where to start looking. Any help would be appreciated.
Old Jan 6, 2009 | 12:30 PM
superduty4x4's Avatar
superduty4x4
You have to be in neutral for the T-case to go into 4 low, have you tried that yet?
Old Jan 6, 2009 | 01:54 PM
senix's Avatar
senix
also put in neutral then shift to 4 low...might have to back it up or go forward just a little and try again to get the gears lined up.
You can go to motorcraft.com and pull down a owners manual.
Old Jan 6, 2009 | 02:00 PM
2000silverbullet's Avatar
2000silverbullet
The brake pedal must also be pressed and the truck has to be completely stopped.
My routine is to throw it in neutral and let the truck roll a little bit (6") so nothing's bound up. Wait until the truck comes to a complete stop, flip the switch, clunk (my case engaging), continue to have fun.
For me, this is all much easier to do if I'm already in 4H. For some reason, going from 2wd to 4L seems to be all too much for my truck to comprehend.
rugerman's Avatar
rugerman
Mine says to engage the brake, shift to neutral then engage the esof to get into 4 low (not sure where you are supposed to hold your tongue-as in not holding your tongue right). Might take a few seconds to engauge. rugerman
Old Jan 6, 2009 | 03:26 PM
kissingbug1978
That got it. You guys ROCK! Makes me feel even better about the small investment I made on this truck. Thanks for the help.
