Slow heater in 1999 F150
Old 12-13-1999, 09:54 AM
rick's Avatar
rick
rick is offline
My 1999 F150 Super cab (5.4) takes a while to heat up. The thermostat has been replaced and seems to work correctly. Once it does get warm, it blows good hot air (after about 15-20 minutes).
Any ideas to improve heater performance?
Old 01-08-2000, 07:13 PM
David's Avatar
David
David is offline
I was experiencing about the same problem on my 98 F-150 4.6L. My problem was that I would only get heat when the engine was turning about 1800 RPM's (Interstate). Then, once I came to a stop no matter how long I had been driving, the heater temp would drop to the outside air temperature. I asked a local mechanic what it could be and he said to check the coolant level. I found out I had a very low engine coolant level. Something, I never check when changing the oil. I added a gallon of coolant and now my truck heats up with 5 minutes at idle given a 50 degree day. After that, I took it to the dealer to have them purge the system since I noticed rust bubbling back at me when I went to pour in the additional coolant. I told the technician what had happen and he said they have seen leaking heater hose clamps next to the firewall. Sure enough, that was were I lost my coolant. They replaced the hose, the sticky thermostat, the clamp and the coolant. Good luck.
Old 01-11-2000, 10:05 PM
trace's Avatar
trace
trace is offline
maverickfe
1997 - 2003 F150
02-22-2014 12:01 PM
Just for Me
1997 - 2003 F150
10-08-2009 10:30 PM
pittbull19
1997 - 2003 F150
10-31-2007 04:19 PM
scar98
Electrical Systems/Wiring
12-19-2005 12:46 AM
bhearn
1997 - 2003 F150
01-25-2005 11:22 PM
Quick Reply: Slow heater in 1999 F150
