motor swap
you are correct the offenhauser or any aftermarket intake/exhaust do not come with heat risers or any form of heating to the intake. either plumb the coolant line to the intake, make a heat riser or drive it in warm weather to get alright atomization.
ALSO if you live in a emissions controlled area (dangit) you can't alter the EGR in any way. this prevented me from going to a Weiand intake on my 302 i had lying around, cant ditch emissions!
you can rig it to make it functional, but its not gonna be pretty.
i love the 300 six but it is profiled on smog tests....
also i'm curious about the v8 because i am going to need the power to haul my stuff all over the country. going into air force and going to be moving alot. would love to be able to smoke anything more than a fedex truck. (yes i raced a fedex truck, trust me when i say send AIR MAIL) but mainly need econmy and pulling power. beginning to like the sound of keeping the i6. i have heard from alot of people about how the engine is a tank. proabbly going to do a 4x4 conversion just so i can always be able to get where i need to be... or atleast stand a better chance to. i will be using this to tow a car and probably a trailer. definately a good load of wood every now and then. any more info you guys want just ask. keep the info comming i am looking into the exhaust tommrow. and here's some pics.
you should find an offenhauser dp intake, it is one of the only dual plane 4bbl intakes and i have heard very good things about it. other than that you got the cheapest and most effective way of waking this i6 up other than adding headers. the i6 wont beat anybody and i mean NOBODY but a diesel chevette, but is able to tow the mountain effectivley or get great economy(compared to the smallblock v8). and yes, it is a tank thanks to 7 main bearings and a pretty dang good oiling system. run it hard! it will stay intact!
the thing i would go for first is the exhaust since it is a 6-1 manifold (wow...) that is the biggest restriction above 1800 i'd say. pretty dumb idea but i guess it works.
to sum it up
-the i6 will work all day and all night nonstop when the v8 needs a beather or can cool off.(even wonder why they are pump motors or electricity generators?)
-the i6 is a tank of a motor and will outlast any v8 (imho, havent run an i6 or v8 very long past 100,000 miles)
-offenhauser dp intake, 390 holley, efi exhaust, y-pipe and maybe bump the timing up to 10-12* depends what its set at.
With the 6 you definitely will not win any races. Running empty it will seem it doesn't have any get up and go at all, and you will be disappointed in it. But get it loaded, and you will be surprised to find it's still it's old doggy self. The load makes a difference, but less difference than with a 302. And you will find when you really need the engine, it seems to pick up some sort of grunt down low and will hold it. Even though you are going slow, it seems more willing to pull.
The 302 on the other hand is a very lively, and willing to rev and running empty seems to have a lot of power and get up and go. Do a little work to it, and it's a very fun engine to drive. But when you put a load in or behind the truck, you will find the difference very dramatic. The "power" seems to go away very quickly. You will find yourself using the lower gears a lot, and having to rev the engine very high to keep moving. You start feeling sorry for the engine because you have to run it so hard, but use any higher gears on a hill, and it will bog down. It just doesn't have that "solid" feel the long stroke 6 has when pulling.
A 460 is the onyl way to go if you're gonna be pulling a trailer. It's just not fun pulling anything substantial with a small block or six. It's also not fun pulilng trailers with short trucks. My '86 F-250 Supercab pulls much better than my '83 stepside did. That stepside had a 302 and was terrible for pulling trailers of any real weight. Heaviest I pulled with it was about 6000 lbs, give or take, and it was a turd. Ate through gas like mad and took forever to get up to speed. That was with engine work too, intake, cam, carb, long tube headers. My '86 has a 351W and ZF5, and it struggles to pull my 4000 lb boat/trailer. Small blocks are pointless, and don't save much gas. When I converted from mild 302 to mild 460 in my car I lost about 1 MPG and gained a whole crapload of power and acceleration.
If it were my truck this is what I'd do... Build a nice mild 460. Ported D0VE heads 9.5:1 compression, Lunati Voodoo or Comp Extreme cam (I like the lobe profiles on these cams) right about 262-268, Edelbrock RPM intake, Holley 750 VS, long tubes into 3" collectors and side pipes. If you got deep pockets do a 4.5" stroke crank for a 545 and go with more duration on the cam to keep it around 6000 RPM peak.
Note to swap this motor in there you can use all factory parts except you will need an oil filter relocation kit as your crossmember has no accomodations for the oil filter. Mount it on the inner fender or wherever you like.
For a trans I'd do a ZF5 to maintain decent highway MPG. They are great transmissions. I'd do a married NP205 on the back. Build a crossmember for it though, as the 205 case is heavy. I'd twin stick it while you're at it, and probably run a 3.73 or 4.10 gear in the axles. Also a double cardan shaft in the rear would be prudent as your driveshaft angle won't be pretty if you do much lift. The ZF5 is a bit longer than the NP435 and will rebuire moving the trans crossmember rearward. The NP205 isn't exactly tiny either.
If want to do a lift on the truck go with a '78-'79 high pinion Dana 44. It's almost a direct bolt in on the '80-'96 F-150/Bronco except you need the lift for the center section to clear the crossmember. If you don't want to do a lift or don't have deep enough pockets/can't find that axle/whatever then a Dana 44 TTB setup is a direct bolt in. You will break it with the 460 if you don't use discretion offroad. Should be fine for street use, snow, dirt/mud roads, etc. My most common failure point on my old D44 TTB was passenger side slip joints in the axle shaft. I always carried spare shafts when wheelin'.
In any event that's what I'd do with the truck. It's all simple, easy, and mostly a bolt in deal.
the i6 will do fine and save some money. i see no signs on my dads i6 faltering that has over 200,000 miles on it.
you bet the 460 will kill any smallblock, but the fact that he has a smallblock trans, light duty rear end and a mileage miser of a i6 (if properly geared) i see no reason why to swap. go get another truck to tinker with or buy a mustang and drop the 460 in and go drag racing
the i6 is plenty of grunt to tow or putz around town and he'd save money because he has it already, not a motor you gotta machine and build.
P.S. a cummins diesel or an international 7.3 will destroy any 460 in towing and economy, one way or the other. or both.
I also think it's a shame to waste a nice stepside on a 2WD six. Regardless, the OP started the thread saying he wanted to do a V8 swap and mentioned the possibility of converting to 4WD. As for the 8.8 not holding up... They are a decent axle and can be made to take some power. A 9 inch will bolt in and take anything a 460 can throw at it. Also a Sterling 10.25" and Dana 60 will also bolt right in. I was not under the impression that the OP was gonna be using this truck for anything more than mild trail riding or street use, so I wouldn't expect the 8.8 to have much trouble.
A 7.3 conversion would be nice but that conversion is a lot more involved. Not certain the OP would want to get involved with such a swap.
What do you call cheap? A good used 460 is hard to come by and pretty expensive to rebuild when you're talking about a $1500 truck. Maybe I'm just jealous cuz I've got a small block.
I have a 1970 f100 sport custom thats my first truck. Its also in about 2000 peices right now. Frame up rebuild. When I bought it it had a 302 and a top loader 3 speed, stock. I added headers and an hei distributor, an big fat tires. It was quick, tons of fun to drive, and great for hauling the dirt bike or quad. I pulled a 400 lb trailer with it once and wont do it again. it got me about 16mpg empty, with the quad in the back 14, I would imagine a rebuilt version could do better but the stroke is just too short for low rpm torque. The 300 i6 is much slower, much better torque and easy to wake up ith aftermarket stuff, but it would cost alot more and never touch my 351. Anywho thats my rant. Good luck.
