clutch bushing fix
Old Jan 6, 2009 | 10:20 AM
MikeFromShiloh's Avatar
MikeFromShiloh
Yea, I noticed the adjustable rod too. Looks like a temp fix for a worn bushing would be adjusting the rod lenght.
I believe I can come up with a cost effective fix. The e-bay fix is $40 bucks. Why not maching a bronze bushing to replace the plastic bushing? Dig through the scrap bin, material would be cheap. Then a little time on the lathe. ......
Old Jan 6, 2009 | 10:31 AM
Talyn's Avatar
Talyn
The plastic takes up a bit of .... play.
The hiem joint allows for the movement, while a bushing would not.
Most people in here know that if you look under there, the damn rod is never in the place its suppose to be anyways, Its out on the end of the rod if it can be. Mines missing the E clip that goes on there, so it moves around. It probably doesn't help with my clutching.
As for the whole f150 to bigger trucks clutch springs. I request heavier springs for mine.
My clutch gives you a work out.
Old Jan 6, 2009 | 01:09 PM
scatgo's Avatar
scatgo
Originally Posted by Eric_F250
thanks for the idea and link! i'll check it out.
looks like a pretty easy in/out repair- how'd yours go?
Unfortunately it was a bit of a pita but not to bad. Heres the details..
https://www.ford-trucks.com/forums/7...ml#post6342137
robert_l_ross
Sep 1, 2023 03:17 PM
reamer
Jan 30, 2016 02:08 PM
smoky_diesel
6.7L Power Stroke Diesel
34
May 27, 2014 11:47 PM
1983F1503004x4
Mar 5, 2013 11:57 AM
nossliw
44
Oct 16, 2012 04:30 PM
