265's to 245's?
Old Jan 4, 2009 | 07:08 PM
wrenchturner's Avatar
wrenchturner
265's to 245's?
I was given a new set of michelin tires load range e. 245/70/17. I have 265/7017's stock. I used a tire calculator it was about 2 mph off at 60. The truck isn't driven much. Its and 03 fx4 with 68,000.
Will this make a huge issue for the electronic trans shift? all 4 tires are new so no 4wd issues with mixed size.
Imho michelins are some of the best rubber on the road. the higher load range would be nice when towing the derby cars and boat. There would be less sidewall play i think.
Old Jan 5, 2009 | 07:24 AM
heymrdj's Avatar
heymrdj
Last I knew there was no Fx4 Expedition...did you mean to post in the F-150 forums?
Old Jan 5, 2009 | 05:20 PM
MisterCMK's Avatar
MisterCMK
There will be no problems. The 2mph difference won't make a difference at all either.
Old Jan 5, 2009 | 07:17 PM
wrenchturner
yep 03 xlt fx4. It has blacked out headlights from the factory, and nerf bars instead of plastic running boards, lsd front and rear.
