Lost Overdrive!
Old Jan 4, 2009 | 11:01 AM
DANA60's Avatar
DANA60
Lost Overdrive!
I have a 2004 f-140 4.6 with edge box on level 2 and 4th gear just stopped working. Everything had been working fine i watched my temp and in shifted well. Then i go to drive it and it shifts 1-2-3 and then just revs. Any ideas? Has this happened to anyone else?
Old Jan 4, 2009 | 12:49 PM
medic92's Avatar
medic92
my 06 did the same thing..it turned out to be the overdrive servo and wiring harness. Luckily mine was fixed under warranty.
Old Jan 5, 2009 | 05:20 PM
DANA60's Avatar
DANA60
I reset my edge back to stock from level 2 and it drove fine then i returned it to level 2 again and everything seems good. I did just update it about a week ago i dont know if there is a problem with the updated probram. My trans temp is usually in the 150 range this time of year it just seems a little hotter than it should considering how cold it can be out. I dont know any info is appreciated. Thanks
Old Jan 5, 2009 | 05:58 PM
AA702's Avatar
AA702
I just got my edge recently and I run the level 1 tune. My truck is also an 04 with the 4.6 and its an XL model. I like the way it shifts now and the throttle lag is gone and the truck just woke up. I like the fact I have a tach now, and I can see my coolant and tranmission temp also. My trans temp runs around 130-140 and its in the 40s-50s here in Vegas. I do service my truck by the book and it has had the coolant, trans and oil changes regularly. Have you serviced your trans fluid?
Old Jan 6, 2009 | 04:11 PM
DANA60's Avatar
DANA60
Yes i had my trans fluid changed about 15000 miles ago maybe i should do it again. I thought of adding a bigger trans cooler maybe that would help. Just seems a little hot unloaded at highway speeds 70-80mph
CFD18KO
1997 - 2003 F150
Jul 28, 2014 06:58 PM
true blue
Aug 20, 2006 08:23 PM
brianwetzel
Aerostar
May 10, 2004 11:08 PM
