5.4 L engine tapping
Old Jan 3, 2009 | 09:53 PM
Kws3sc's Avatar
Kws3sc
My 97 Expedition 5.4L w/171,000 miles engine is tapping. This started in the past 350-400 miles. And right after I had the oil changed. It it sounds like it is coming from the top of the engine and is doing it on both sides. How do I make it stop?
Old Jan 3, 2009 | 10:10 PM
truckeradg86's Avatar
truckeradg86
Use the proper 5w20 ... if that doesn't work out lucas is your next bet
Old Jan 4, 2009 | 12:05 AM
alloro's Avatar
alloro
Must use only a Motorcraft oil filter.
Old Jan 4, 2009 | 06:03 AM
Oldtrucknut7077's Avatar
Oldtrucknut7077
I only use 5w30 Motorcraft oil and Motorcraft oil filter (FL820S). Make sure the proper amount was put in. I know mine calls for 6 qts of oil.
Old Jan 4, 2009 | 07:17 AM
Z06PSI's Avatar
Z06PSI
Is it tapping or does it sound like sewing machine? Could possibly just have a loose rocker.
Old Feb 27, 2009 | 03:49 PM
Kws3sc's Avatar
Kws3sc
thanks guys. Changed the oil, used 5w30 oil and a motorcraft filter and it is running fine.
Old Feb 27, 2009 | 05:19 PM
Oldtrucknut7077
I'm glad you got your tapping to behave.
