03 Expy Starting hard
Old Jan 3, 2009 | 09:45 PM
FordMan1212's Avatar
FordMan1212
03 Expedition with 113,000 miles takes 2-3 attempts to start. New plugs did not help. Starter cranks fast enough, just wont take off. Thoughts?
Old Jan 3, 2009 | 10:21 PM
truckeradg86's Avatar
truckeradg86
If its not spark its fuel long as there is no cel try lucas fuel injecter cleaner to clean the fuel system up ... could be a number of things really fuel air filters sensers. Best bet is to get a diagnostic done at a firestone or local tire shop then do the work yourself labor gets pricey......
Old Jan 4, 2009 | 12:08 AM
alloro's Avatar
alloro
Press slightly on the gas pedal the next time you attempt to start it. If it starts considerably easier your AIC valve is sticking. Another possibility is low fuel pressure.
Old Apr 18, 2009 | 04:03 PM
FordMan1212
AIC Valve
Can anyone explain where this AIC valve is exactly? Cant find a manual on this year.
Thanks in advance!!
Old Apr 18, 2009 | 10:26 PM
alloro's Avatar
alloro
5.4 top rear of engine.
4.6 top front of engine.
