Parts
Old Jan 3, 2009 | 07:32 PM
tsullivan's Avatar
tsullivan
Parts
OK, I took the groups advice and welded the rear shock mounts back to the axle. All's fine there.
Now, the wife is complaining because she can not open the passanger door or roll down the window because both handles are stripped. What are the best couple of online part catalogs you recommend?
1964 f100
Thanks.
Tom
Old Jan 3, 2009 | 07:38 PM
Redmanbob's Avatar
Redmanbob
Buy the wife a western flyer cycle and leave the truck be sorry lol
Old Jan 3, 2009 | 07:41 PM
jowilker's Avatar
jowilker
Tom, I would go yarding and remove those parts and bring them home.
John
Old Jan 3, 2009 | 07:43 PM
camperspecial65's Avatar
camperspecial65
If the handles themselves are stripped thats an easy fix...I have some NOS 2nds...the cranks ***** arent perfect...but the chrome is good...if after you get the handles off the regulator and door mechanism is bad I dont have a window regulator but I would need to dbl check on the door opening mechanism.
Drop me an email or message for price on the handles if interested. Are you only needing the inside handle and window crank for 1 door or both ??
- cs65
Old Jan 3, 2009 | 08:09 PM
tsullivan's Avatar
tsullivan
Ha ha, pretty funny but not too helpful. I've browsed thru a few parts catalogs I found with Google but there must be one or two the group recommends.
Old Jan 3, 2009 | 10:40 PM
drof46's Avatar
drof46
I had some extra doors last time this happened. May try some scrap yards and pray. I'm sure someone still makes them, but doubt you will enjoy the price.
So this didn't happen to my new old ones, I took my handle down to fastenal and had them give me a allen screw/bolt to replace the phillips head screw/bolt. Never could get the phillips head as tight as I thought it should be. The allens work like a charm.
Old Jan 3, 2009 | 11:35 PM
garbz2's Avatar
garbz2
Most times the handles are not stripped only installed incorrectly.
If the handle spins the shaft may be toast, remove them and inspect the splines on the shafts. if these are bad you are SOL. You need new window regulator or as some enterprising persons do some vice grips till new or used can be sourced.
The regulators are available new from just about every FTE supporting vendor.
If they are not stripped back out the screw and push in the handle fully and tighten up the screw.
Garbz
TGoodwin
Australia Chapter
Dec 1, 2013 06:32 AM
caseys
Washington Chapter
31
Jun 27, 2010 01:17 AM
Placermike
Washington Chapter
503
Dec 2, 2007 09:52 AM
BIGTSV
Mar 14, 2005 08:06 PM
