Busted bolts in W/P
Old Jan 3, 2009 | 08:24 AM
87bronco58's Avatar
87bronco58
Cool Busted bolts in W/P
Hey any help would be appreciated. Ihave a 98 mounty 5.0 AWD wnt to change water pump last week and broke one themostat housing bolt the very top short water pump bolt and the left side long waterpump to head bolt ( I am not a newby when it comes to ford small blocks. I used BP soaked for days ,heat and a welder to get these out I believe a not so Easy out will break and then Ill be really screwed any ideas?????:?
Old Jan 3, 2009 | 10:26 AM
aquanaut20's Avatar
aquanaut20
If you fear an Easy-out will break, drill and tap now and eliminate the aggravation.
Old Jan 3, 2009 | 10:28 AM
393STROKER's Avatar
393STROKER
Did you try to weld a nut onto the broken bolts?
Old Jan 3, 2009 | 10:40 AM
aquanaut20's Avatar
aquanaut20
good call stroker,
Since he mentioned welder I made the ***-u-m..tion that he had gone that route already.
Old Jan 3, 2009 | 03:30 PM
87bronco58's Avatar
87bronco58
Red face
sure did I just keep snapping it off shorter so I think drill and tap would be my best betany other quick fix ideas???
Old Jan 3, 2009 | 04:08 PM
HomerWinzlow's Avatar
HomerWinzlow
I always had to pull the front cover and tap them out. Be carefull or you can break the front cover too.
