Replacement leaf spring
Old Jan 2, 2009 | 09:48 PM
rusty9cab's Avatar
rusty9cab
Where can I buy a decent replacement rear leaf spring for my dually? The passenger side spring has lost one of the washer shaped spacers in between two of the leaves and the metal to metal contact is starting to wear into the spring. I have tried to replace the spacer with similar thickness washers of different diameters and none of them will stay. Also, do I need to replace the top "helper" section of the spring or just the bottom leaf section. Thanks guys.
Old Jan 3, 2009 | 07:38 AM
heathrunkles's Avatar
heathrunkles
4 years ago I got mine from KC spring works. They where priced about the same others. Mine was single rear wheel though. I think for around 800 I got all four springs done. I went with a heavier rear pack as well.
THere is an ad in your original post from them--go figure!
