Will it work???
Old Jan 2, 2009 | 09:27 PM
tobacco farmer's Avatar
tobacco farmer
Will it work???
I was wondering if a 06 motor will work in a 03 6.0. I found one that only has 3k on it and if everything will work I would rather put it in instead of fixing mine. Thanks
Old Jan 2, 2009 | 09:36 PM
rollerstud98's Avatar
rollerstud98
what is coming with the 06 motor? who are you going to get to do the swap? what is wrong with your current motor?
Old Jan 2, 2009 | 09:47 PM
tobacco farmer
Just the motor and wiring, Im going to do it, My motor has bad head gaskets on it and im always having to nickel and dime it so I figured the 06 had less issues with it correct me if im wrong.
Old Jan 2, 2009 | 09:56 PM
rollerstud98
I think a lot of the issues were due to the techs not really knowing what they were doing. I'm not sure about all sensors but I know that the ICP sensor will be in a different location on the 06 then on the 03. If swap all of your computer hardware over to the new motor you'd think it would work.
Old Jan 3, 2009 | 09:31 AM
6LPSD's Avatar
6LPSD
i second rollerstud, to do the swap as cleanly as possible you need all the wiring harness, ecm, ficm and any and all wiring electrical stuff from the 06 to swap into the 03 truck
the engine should bolt up to a 03 tranny with no problem, i dont think they switched bolt patterns in 3 yrs, is it an auto to manual or manual to auto swap? there may be different programming between these two but i am not certain.
