suspension problem
Old Jan 2, 2009 | 08:08 PM
kevinjjedwin's Avatar
kevinjjedwin
suspension problem
my o6 navigator dash say" check suspension ".while the air pump works.now I do not know if one of the height sensor is not working will cause that problem and if the same sensor will cause the truck not to raise.does any one ever had this kind of problem with the suspension .appreciate any help .thanks
Old Jan 2, 2009 | 08:36 PM
pdqford's Avatar
pdqford
You need a Ford Specific scan tool to read the suspension DTCs (although I think I heard that only the NGS can read the codes on the Navigator's suspension - its computer uses a different protocol than the Expedition's.)
Old Jan 3, 2009 | 03:55 PM
kevinjjedwin
hey pdqford,you don't know if the height sensor in the rear might have cause this problem because the rod on the sensor was broken.one more thing does the suspension module need programming to raise the truck .apprciate the help
