Sponsored by: Kumho
tire pressure sensor question
Old Jan 2, 2009 | 07:18 PM
vetteguy96's Avatar
vetteguy96
If I buy a set of wheels and tires off of an 08 F150, I have an 07, will the tire pressure sensors work automatically or will I have to do something to get them to work? Thanks, Guy
Old Jan 4, 2009 | 07:16 PM
bfgfocus's Avatar
bfgfocus
they should work if they are both the same type of sensor. For example ford has the banded sensors which are attached to the wheel internally by basiclly large hose clamps. But there is also the valve type sensor which is like its name a 1 peice sensor/valve. If you have to have them switched out you will have to take them to a tire dealer.
