Sponsored by: Kumho
dropping the front end
Old Apr 3, 2000 | 06:43 AM
64short100's Avatar
64short100
I have a 64 short bed (hence, my name)and was wondering if anyone has a good, safe and economical way to drop the front end 2-3". I have heard that you can remove a couple of leafs from the springs, is this advisable? What else would be involved? Has anyone used another method with good results? Thanks for the help.
Old Apr 20, 2000 | 03:23 PM
3179crew's Avatar
3179crew
I would advise using a drop axle or MustangII front end, if you lower it by altering the springs you will lose suspension travel. When the front axle bottoms out on the bump stops/frame it is real scarry!! (I've been there).
L. Edmundson
31 crewcab
35 pick up
72 F-100 lowrider
79 F-150 crewcab (custom built)
Old Apr 22, 2000 | 09:13 PM
jkt's Avatar
jkt
