Ok Gearheads.. Transmission problems...
So far the following tunes cause transmission issues;
- SDT - Ultra Comp
- SDT - Aggressive Street
- ID - Street
- ID - Aggressive Street
What's happening.. Various tunes cause various problems..
- Leave from a light, transmission goes to high gear, then back to low gear.
- WOT instances where 3rd gets stuck, then shifts to fifth. Notice a loss of engine noise and an increase in turbo whistle.
- Sometimes at 1/4-1/2 pressure gear shifts are sketchy, slippy, or rough.
- No codes thrown.
- Transmission temp gets up to 170-175 quite frequently unless it's 40's outside.
- No decrease in fuel pressure in any instance.
- No lack of turbo boost in any instance, or drop thereof.
- Transmission fluid smelled like crap (normal smell), nice cherry color, not burnt. Afterward electronics under pan look normal.
- Oil pressure is good, oil is good.
- Drive-train inspection was good. Slight knock in rear, probably needs a re-grease on the splines.
- EGR checked, fine.
- VGT DC Cycle appears fine.
I started to push the theory with the lift and 35's, but all my calculations can't confirm a cause because the weight isn't that severe.
Any thoughts?
