my parking brake light and my ABS light are staying on while im driving in my 94. i know the P brake isnt dragging. and is the ABS light supposed to stay on?
i dont know where to start, is it electrical? cause thats what im thinking.
No the ABS light should not be on while driving. IT should only come on for a few seconds when you first turn the key on.
First thing to do is make sure your brake fluid is topped up. Second thing is to clean the wiring connector at the master cylinder. Then, providing your parking brake switch is not defective of being held on, the most likely cause of both lights staying on is a defective fluid level sensor.
hey thanks for the help, i checked the fluid level and i was good. i took off the connector and cleaned it pretty good and i seems pretty good. i will have to take it out for a drive now and see what will happen.
