help! electrical issue
Old Jan 1, 2009 | 10:42 PM
94F350IDI's Avatar
94F350IDI
Unhappy help! electrical issue
hello and happy new year to everyone!. I have a bit of an issue with my 1994 ford f350 7.3 idi. this morning i went to start my truck up and noticed that my left turn signal stuck on. (with a sold arrow on the dash) the right directional works fine and blinks. also when i turn off the headlights and then try the left directional EVERYTHING blinks?? both right and left sides (even the top cab marker lights). i replaced the turn signal assembely on the column and the problem is still there. any ideas?
Old Jan 1, 2009 | 10:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Check the left turn signal sockets for incorrectly installed bulbs and grounds.
Sounds like a bulb problem to me the more I think about it.
Turn signal power is going into the park light circuit.
Do you have a trailer wiring harness/socket?
Thats a good place to find problems like this also.
Old Jan 1, 2009 | 11:09 PM
joe f350's Avatar
joe f350
iam have a simlar issue but iam rewiring my hole truck
Old Jan 2, 2009 | 01:24 AM
RCrawler's Avatar
RCrawler
Sounds like you may have a bad ground in the L side and it is back feeding through the marker lights to find a ground.
With the left turn signal on, are both the front and rear exterior light illuminated?
With the emer flashers on, does the problem still exist with the markers (cab lights)?
Since the RH is working fine, with the flashers working, watch the left side lights for the one that is in sync with the RH side.
And then check the ground for the light that is out of sync. It may be in the bulb, the connection or the chassis ground.
Jason
Old Jan 2, 2009 | 04:38 AM
fonefiddy's Avatar
fonefiddy
Check the headlight switch wiring harness. They can get hot and melt, often effecting more than just the headlights.
Old Jan 2, 2009 | 10:59 AM
starmilt's Avatar
starmilt
Ford headlight switches are famous and a pain to get . relays.
I second the trailer wiring and socket if you have one.
I had that acted like this drove me nuts found where somebody forced a 1156 bulb in to the tail light socket instead of a 1157.
Old Jan 2, 2009 | 11:39 AM
94F350IDI's Avatar
94F350IDI
does anyone have a headlight wiring diagram for my truck? 94 ford f350
Old Jan 4, 2009 | 06:26 PM
94F350IDI's Avatar
94F350IDI
well. i fixed it. it was the trailer wire harness.
Old Jan 4, 2009 | 06:27 PM
94F350IDI's Avatar
94F350IDI
thank you for all of your help !
Old Jan 4, 2009 | 06:58 PM
starmilt's Avatar
starmilt
Thanks for letting us know what fixed it.
