2004 Ford Excursion Trailer Wiring diagram
Old Dec 31, 2008 | 07:28 PM
sltrrco's Avatar
sltrrco
Question 2004 Ford Excursion Trailer Wiring diagram
Like the title say, I need the trailer wiring diagram for the trailer plug. I have short and it looks like it might be the plug. Any help Please....
Old Dec 31, 2008 | 09:11 PM
cangim's Avatar
cangim
This should be standard from ford, it will give you the wire color and function. I don't have a picture/description of the plug though:
Color - Function
Dark Blue - Trailer Electric Brakes
Orange - Trailer Battery Feed
Yellow - Left Stop Turn
Dark Green - Right Stop Turn
White - Ground
Brown/White - Trailer Running Lamps
Black/Lt Green - Trailer Backup Lamps
Old Dec 31, 2008 | 09:35 PM
Steina's Avatar
Steina
CO River Rat
Here's the industry standard: Trailer Wiring Diagram For 4 Way, 5 Way, 6 Way and 7 Way circuits
Steve
Old Jan 1, 2009 | 10:57 PM
sltrrco's Avatar
sltrrco
Well here is a Update, The lights are all fixed on the trailer. I had to replace the plug on the truck. Watch out if you own a Pace Trailer check all the wiring it is crap. I had to rewire the hole trailer.
Old Jan 2, 2009 | 08:36 AM
Steina's Avatar
Steina
CO River Rat
Did Pace use ScotchLock splice connectors on the wiring? If so, hopefully you replaced them all with butt splices and shrink tubing.
Steve
Old Jan 2, 2009 | 10:18 AM
sltrrco's Avatar
sltrrco
Yes, I replace them with butt splices and srink wrap. All of the wires had suitcase connections on them and were the wires ran though the frame for all bad. Here is a tip for everybody go to lowes or home depot and get some of the gray plastic condiut couplers and put them thru the frame not the cheap plastic inscerts that pace used they just fall out.
Crewcab Turbo
Apr 11, 2024 02:17 PM
straightsixer
All Things Towing
Feb 1, 2015 10:59 AM
Dave145
Aug 17, 2013 12:35 AM
2006SDpower
Jul 26, 2011 11:51 AM
BENG0924
16
Oct 17, 2008 04:20 PM
