1978 - 1996 Big Bronco
wandering front
Old Dec 31, 2008 | 01:08 PM
black92's Avatar
black92
wandering front
I have a 92 Bronco and the front end wanders a bit. It has leveling springs on the front. Firesotone Destination A/T,s with 30% tread left. The truck has over 200,000 miles on it. I was tolled the alignment is good and it has a new stearing box. I do notice some possitive camber. Does anyone have some suggestions were to start to fix this problem
Old Dec 31, 2008 | 01:31 PM
bigunred's Avatar
bigunred
Check your pivot bushings in both axels, where the conect to the frame, and your radius arm bushing, the long arme conecting to your axles. and lay under the front of yourtruck with the tires straight and have some one wiggle the steering wheel back and forth looking for loose tie rod ends. Then fianally jack up one side at a time and using a board or long handle try lifting the tire up and down looking for your balljoints to move if they do you need new ones. the baljoints are where your tires and spindles pivot at. Let us know what you find. Was the stearing box adjusted? Jay
Old Dec 31, 2008 | 01:33 PM
helirich's Avatar
helirich
Have someone rock the steering wheel while you look underneeth. You can usally spot where the play is. The steering box could be shot even if its new.
Old Dec 31, 2008 | 01:43 PM
black92's Avatar
black92
Thanks, I'll try those suggestions. I did install new ball joints about a year ago.
Old Dec 31, 2008 | 01:48 PM
bigunred's Avatar
bigunred
was the stearing box adj. when it was installed ?
Old Dec 31, 2008 | 02:07 PM
black92's Avatar
black92
The stearing box was installed before I bought it. I'm not sure if it was adjusted properly.
Old Dec 31, 2008 | 02:15 PM
b4hntn's Avatar
b4hntn
If it turns out to be in the steering box I can save you some repeated headaches. The one I got from Red-Head Steering Gear in Seattle is absolutely fantastic. Yes, they ship and take a core in return when yours is off. Don't adjust the new one, once it breaks in it is perfect.
Old Dec 31, 2008 | 08:06 PM
greystreak92's Avatar
greystreak92
Check the red link in my signature. The front end suspension components include as many as 16 different movement points all of which have rubber bushings that will eventually wear out (especially at 200K on the ticker).
2 - radius arm bushings
2 - axle pivot bushings
2 - upper ball joints
2 - lower ball joints
2 - sway bar bushings (plus two sets of end link bushings)
2 - shock absorbers (each with an upper and lower bushings) (quad shock front ends double this number).
2 - inner tie rod ends
2 - outer tie rod ends
I'd almost be willing to put even money on one or more of these components being the problem child in this case.
Old Apr 5, 2009 | 01:20 PM
black92's Avatar
black92
Well I finally got the original axle pivot bushings replaced and the truck is back on the road after fixing some electrical issues. I notice that it pulls to the left now, so the alignment is off, but I still have more play in the steering than I would prefer. I had my wife turn the steering wheel while I was under the truck and didn't notice any slop any place. The old bushings were bad. The radius arm bushings are next to be replaced. I might check the rear suspension, I've noticed some popping noises when I go over large bumps or back over any bumps. Thanks for the input. Sorry it took so long for an update.
Old Apr 7, 2009 | 03:25 PM
tom2131968's Avatar
tom2131968
I need to replace my axle pivot bushings and wonder if somebody has written a step-by-step. The writeup in the Haynes is, in a word, scary, as it makes it out to be a 12 hour job. I have caught other posts which say it's a snap but don't provide much detail. Any help is greatly appreciated.
Old Apr 7, 2009 | 08:34 PM
b4hntn's Avatar
b4hntn
Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home again, if the steering box gives slack in the wheel.
